I have been away from this forum for a while. I just got a 1988 Mesa MKIII Blue stripe and I already performed the "+" mods on it. C30 to 1000pf, C27 to 20pf. But, I noticed at another forum the proof that the OT primary just has extra wires coming out of it, but they are not tapped. That seems to be the case on mine. The voltages are 490-491+ on all four primary wires on pin three of all four tubes. Anyway, I have three questions.
1. The MKIII schematic calls for double the filtering on the Simul-Class Models. From 110uf to 220uf on the first stage!!!!! Mine has that. Why is that much necessary on the Simul-Class models? I can't see any reason why, what am I missing?
2. Should I ditch the whole Simul-Class wiring and just use four 6L6's in standard wiring? The new Mesa John Petrucci model has done this.
3. I hate onboard spring reverb. Anything bad if I just pull out the Driver tube and disconnect the tank? I can't see any issue other than a slightly less draw on the PT.
Thanks all of you!!!!
