Larry carlton ported/sealed EVM-12-L cab made
				andresound
Re: Larry carlton ported/sealed EVM-12-L cab made
This is NOT gospel... just my experience and opinion with the brands I mentioned!
I bought one of these when  they were about £35 and learnt how to use it. Now its very easy indeed to knock a shell or cab together using it.
http://www.axminster.co.uk/axcaliber-do ... jig-502514
Unfortunately they are now over double the price.
- norburybrook
that look great, at £35 I'd have bought one definitely.
My screw and glue is working well though so I'm in no immediate hurry to spend needless cash
your cab looks great though.
Marcus
P.S. where do you get your ply?
Marcus
From B&Q simply because they will cut the sheet free of charge, saves me getting my table saw out and enlisting help to run a heavy sheet through it. I'd prefer 15mm but they only sell 18mm. I use 15mm for the front baffle and 12mm for the rear . Baffle mounts are just softwood strips glued and screwed.by norburybrook
One thing I would recommend though is installing all 8 Tee nuts for the speaker mount. If you only have 4 and strip one you've got a problem. It is possible to replace one but you then risk damaging the grille cloth .
If you're ever passing through Nottingham (ideally on a Monday as we have the rehearsal studio all day so can really crank it) and have a spare hour I'd love to do a comparison to your amp/cab. I love my 2x12 with Emi Red Fang and EV and would like to compare it.
