Doing the headphone tuning of the transformers. The quietest spot was not one I would have suspected to begin with so I'm glad I did it. One downside to the 125 series from hammond is its open design makes it slightly more prone to picking up hum.
Test mounting transformers.
Ran into a bit of a problem with the PT mounting. The hole I drilled was a little to far forward away from where the wires come out of the end bell on one side. Ended up having to widen the hole so that the wires wouldn't get pinched by it. Just something to be mindful of if you're using edcor transformers. Had to learn that one the hard way. The end bell goes down to about as low as the mounting brackets and leaves very little wiggle room for the wires to come out. Also the snap bushings I ordered were a bit too small for how many wires were coming off each side of the PT. They fit but its a pain in the ass to get them all through. 4 are unused but again since the endbell goes all the way to the bottom of the transformer I can't heat shrink and cable tie them up top.
Once the hole was widened I fixed in the snap bushing with a bit of hot glue. I was thinking about using something stronger like jb weld or some other epoxy but I would have a hell of a time with it if it still somehow didn't line up properly. The bottom of the transformer along with the tension of the wires holds it in place. Still I'd rather not have to resort to using hot glue in an amp. Its always something lol.
Heaters wired up and terminal strips installed. Those with a sharp eye may notice I somehow managed to wire the pre-amp heaters one pin off. Didn't catch it till later and I was too tired at that point to fix it. Will correct it tomorrow.
Pre-amp grounds installed and starting on the power supply.
Power supply partially completed, transformers installed. Was at about this point I noticed my mistake with the heaters.
