I'm looking at different head cabs that were built for various projects.  While I'd love to make a dovetail cab I'm not sure i'm quite ready yet.  Although i have some scrap wood to practice with.
I like the simple look of the miter joint as well. For those that have built a cab with miter joints how its this held together.  Are you just gluing them together?  Or are you using some hidden dowels along with the glue?
If you properly glue the 45's together can you expect it to hold well or would you also suggest reinforcement?
I've read stories of people gluing 2x4's together with titebond and then smashing the 2x4 over their sawhorse and the glue joint held up while the 2x4 broke elsewhere.
Thanks,
						Wreck Head Cab
Re: Wreck Head Cab
I mitered the corners and used biscuits/glue to hold them together.
						Re: Wreck Head Cab
Thanks.  I've been eyeballing a biscuit joiner.  It gives me a reason to buy a new tool  .
.Re: Wreck Head Cab
So, no reservations about the whole amps weight.........supported by a couple of biscuits and glue?...      I guess I overbuilt mine, with stiffners in each corner, for added strength............  but then again I'm a metal guy.......
Anyone use those kreg jig things?
Re: Wreck Head Cab
My biscuits and glue cabs have stayed together after all these years.
I ordered a Marshall cab from Splawn once and it was put together by Craig pocket holes.
						- dorrisant
Re: Wreck Head Cab
Biscuit joints are apparently much stronger than you are think... They are usually stronger than the wood itself. Don't be limited by thinking otherwise.
						Re: Wreck Head Cab
I prefer dowelling  There are many great jiggs out there that make the process easy
