Heretical TW build
Heretical TW build
Hi folks,
It's my first successful TW-style amp. Rebuilded from vintage German amp Regent MV3. Beautiful sound and awesome touch-sensitivity!
						Re: Heretical TW build
Wow! awesome!
That's quite the tight package. I imagine that would have taken quite some tweaking to get quiet and stable.
I'm responding before looking closely at your schematic. I did notice your treble shift switch.
Very cool adaptation. Do your tubes all fit within the height of your front panel as well?
+1 Wow! Patience, skill, and sexy components. Nice job!
Yikes that's a tight fit!
Well done in keeping it stable.
Looks very nice. Seen a bunch of these old regents being rebuilt around. Moded an amp built with regent transformers with some sort of Matchless schematic in mind. Sounded quite good.
Niki
						Niki
Thanks, guys!
Synchu, In Yugoslavia, Regent tube amplifiers (MV3, Regent-30, Regent-60) must meet often. Very good quality of output transformers! And acceptable power trafos.
My best tube set for this amp:
V1 - JJ ECC83s
V2,3 - TungSol 12AX7 (Russian RI)
V4,5 - Telam EL84
No hum or noise, no sizzle, "honey overdrive" only .
						Yes, all fit and covered with a casing.bcmatt wrote:Wow! awesome!
V1 - JJ ECC83s
V4,5 - Telam EL84
				telentubes
An impressive use of space.
				andresound
You must have VERY small hands   Well done
 Well done
									 Well done
 Well doneIf it sounds good, it is good! Trust your ears
Thanks!
Conventional arms, conventional soldering iron . All work done on a small internal chassis, which is then inserted into the box. Then soldered transformer and pot wires. That's all
. All work done on a small internal chassis, which is then inserted into the box. Then soldered transformer and pot wires. That's all  . It could accommodate the full 30W  Liverpool, with PS board near to power transformer.
I noticed the following changes: the sound becomes more mellow.
. It could accommodate the full 30W  Liverpool, with PS board near to power transformer.I noticed the following changes: the sound becomes more mellow.
- RJ Guitars
In the old days it was said that the only way you could ever make a Wreck stable was to wire it exactly as Ken Fischer did... well at least some folks said that and a few others believed it. Good job and thanks for posting that.
http://www.rjguitars.net
				studiodunn
Super cool and as said, great job on the space available. I am really into the resourcing of amps idea.
Hi folks!
Next time old Regent MV3 rebuild to TW+VOX-style amp: Songwrighter+AC15(pentode) inputs and PA with no GNFB. TW-style side: sweet touch-sensitive tone (rich crunch at full Volume, to right pos). VOX-style side: сut-through singing agressive overdrive. Front panel - customer's work.
Customer gigging with this amp. I got remark: too bassy on both channels, 2x12 cab with Altek-417C. On TW side - change R11 to 2M8, on Vox side - change C5 to 2n2, change C13,14 to 22n both. Voila! Tight bass with no excess. Once again convinced: TW - luxury amp.
						- RJ Guitars
Very nicely put together... Thanks for posting the schematic and photos. Sounds like you found a really nice combination. Any thoughts about using a relay to switch between channels?
