removing the LOW input on a 2204 while maintaining the tone
- Curranproducer
I will never use the low input jack on my 2204 build, I want to get rid of it and use that jack whole for a solo boost jack input. should I run 2 wires from the hot of the HIGH jack to the original LOW jack connection to maintain the tone and gain of the JCM800?
									Curran
Owner of Custom Audio Mutation Recording Studio, Guitar/Amp/Pedal Repair, and Mod center in Akron Ohio
Devout Distortion Worshipper and fan of warm hugs
234-788-6141
234-788-6141
Re: removing the LOW input on a 2204 while maintaining the tone
You can remove the Low jack and associated wires completely (red in attached schematic), and create one new connection (green).
						- Curranproducer
that worked wonderfully! the only thing is I now have a little "chirp/squeak" in the amp when I palm mute the hell out of it on the lower strings. could this be a cold solder joint from the moves i just made?
									Curran
234-788-6141
234-788-6141
New issue? Can't imagine what.
						- Curranproducer
it turned out to be the V1 LITERALLY went microphonic after I put this back together. swapped out the tube and blamm-o chirp is gone
									Curran
234-788-6141
234-788-6141
				Martymy800
Could anybody draw a Cliff jack wiring for a single high only input jack?
Thx
						Thx
				Martymy800
I am following the Mojotone schematic. Does this look correct. I finish it but there is no gain. It seems is wired as the low input instead of the high.
