My latest build
Re: My latest build
got my rear sight , an h2 buffer and a few mags .
the rear sight confirmed what i was fearing .My riser for my reddot is to talll.
when i tried bore sighting it i ended up with my front pin all the way to the top of the ears and it looked like it still needed to come up. but i figuered it was just me.
so when i shot it it was still shooting hi. I figured well im no wild bill . im probably flinching or something.
guess ill save the dot for another gun I dont know how much riser blocks cost but im already getting more money than i wanted in it.
I found a shorter block on amazon for ten bucks . Guess i can swing that
Re: My latest build
You are starting to see the perils when putting this stuff together. I'm not advocating being a total brand whore, but I avoid cheap junk or knockoffs like the plague and I repeat what I said in one of my very early posts about the market is flooded with junk and to avoid it.cbass wrote:got my rear sight , an h2 buffer and a few mags .
There's a whole junk clone industry which originally came out of the airsoft craze and then it trickled over to well let"s fit on a real gun and sell it for cheap and because it looks like the originals, folks will buy it. Nevermind that the specs are off, but who cares because it's cheap.
I was going reply with a drawn out reply about co-witnessing, but I found this on the web.
http://www.guns.com/2013/02/06/red-dot- ... itnessing/
TM
Re: My latest build
well ive tried to research everything i got.  I hope you were refering to the riser I mentioned and not my gun    . Its a bushnell red dot not exactly high end but it works
the BUAS I got is very well made and I think it is going to work just fine.
In high school everyone was a ford or chevy guy but my offbrand pontiac smoked everything in town but no defanitly dont want chinese airsoft parts. I dont plan playing GI joe or anything but i defanitly dont want my sights coming loose.
http://www.amazon.com/UTG-Med-pro-Compa ... iser+mount
I gotta order some crap anyway the revies are good so i guess fro ten bucks ill put some china on my gun. i dont learn easily
  . Its a bushnell red dot not exactly high end but it worksthe BUAS I got is very well made and I think it is going to work just fine.
  but no defanitly dont want chinese airsoft parts. I dont plan playing GI joe or anything but i defanitly dont want my sights coming loose.http://www.amazon.com/UTG-Med-pro-Compa ... iser+mount
Re: My latest build
Your gun is finecbass wrote:well ive tried to research everything i got. I hope you were refering to the riser I mentioned and not my gun. Its a bushnell red dot not exactly high end but it works
In high school everyone was a ford or chevy guy but my offbrand pontiac smoked everything in townbut no defanitly dont want chinese airsoft parts. I dont plan playing GI joe or anything but i defanitly dont want my sights coming loose.
UTG aka U Got Took is usually mentioned in the same sentence as Air Soft junk, but you decide how to spend your coin.
TM
Re: My latest build
guess ill look fir something else
						Re: My latest build
ToneMerc wrote:Magazine, not clip.....sorry it's my firearms pet peeve OCDNickC wrote:
A gentleman in Buffalo was riding as passenger when his wife was pulled over for a traffic check. Out of courtesy he told the officer he had a pistol permit and the pistol was in the glove box. Officer asked to see the gun, removed the clip and counted there were more than seven rounds. The gentleman was arrested and taken to jail. Learning of the incident, a local judge ordered the state police to go to the mans home, providing them with a warrant to remove ALL firearms.
The "crime" of having more than seven rounds in the clip is a felony. As a felon, the gentleman would be prevented from ever owning a firearm again (of any type).
This incident went through appeals process and eventually the gentleman was vindicated, and the felony conviction reversed. In any case he was traumatized and victimized by run-away-DRACONIAN enforcement of unconstitutional laws.
TM
I stand corrected!
That being the case, I don't think I want my face on the cover of a magazine after all.
Re: My latest build
What model Bushnell red dot do you have?cbass wrote:guess ill look fir something else
TM
Re: My latest build
Somehow i Didn't see your reply . it's a trs-25 I believe . actually things seem to be working out with the cowitness thing . I guess it's supposed to be lower third with the riser that came with. just buy bore sighting it all lines up.
So if I look over the sights the reddot should still be Poi ?
I actually like looking at the dot through the aperture. Guess I have stigmatism. The dot looks much crisper and like a tiny dot instead of 5 or 6 dots blobbed together. I'm down to my weak eye ya know.
Re: My latest build
Yes, however check the POI with the red dot at various increments out to let's say 100-125 yards just to get a baseline with that particular ammo. Also keep in mind POI will change with variations in ammo.cbass wrote:Somehow i Didn't see your reply . it's a trs-25 I believe . actually things seem to be working out with the cowitness thing . I guess it's supposed to be lower third with the riser that came with. just buy bore sighting it all lines up.
Sounds like once you get the stock and pistol grip upgraded you will be squared away.
TM
Re: My latest build
Yes the grip I wrapped some tape around it. It made it fatter but my hand needs to sit back way farther. I can still reach around the trigger and touch my thumb with my trigger finger. I was gonna order the maid grip but they were out of black by the time I ordered. I thought about carving some out of this hard ass tropical wood I got . I'd just be to much work.  may as well be machineing them out of aluminum. But I do like wood grips.
I may still carve a back strap for it and more graffers tapes . I don't need no fancy lookin gun
Oh gotta put on my ambi saftey I got too
Ive got a couple of days off this week hopefully I'll get a chance to really run this thing. It's 7 degrees this morning I bet the range is empty . got a couple thousand rounds of some m855 to break it in
Re: My latest build
Feelin mighty tuff
						Re: My latest build
That's pretty good, I paid around $850 for my Colt around 1994.cbass wrote:I'm new to the AR platform. The amount of choices is pretty overwhelming . I hope I did OK .
I have right about 600 in it including the reddot and 40 rounder.
Nowadays you can buy separate parts and put together the rifle of your dreams!
I think one of the beauties of the AR-15 5.56 rifles is the lack of recoil.
Although I love shooting my paratrooper model SKS 7.62, the AR-15 is in a class by itself.
Devastating firepower and accuracy is what I like.
When I knew I was getting married, I bought a few guns before to avoid any argument about money.
Me and my buddy were in the "buy one gun a month club"when I was single, for quite a while.
.There was a local gun store that sold guns pretty much at wholesale price, this was just before the internet was common.
So they just sold volume instead of trying to make a killing on each gun.
I miss that place a lot.
25 years ago or so, just about anybody could get a Federal Firearms License.
My coworker had one and we bought a lot of guns.
Sad to say when I didn't have work for a long time I had to sell off some to make ends meet.
But I still have my favorites.
I think the coolest gun I have is a Kimber 1911 .45acp.
I bought one when they first came out.
It's a beautiful pistol and accurate.
Re: My latest build
I put a couple hundred rounds through it today .ran great the H2 buffer reduced recoil a lot. an ol boy at the range let me use his sled to sight it in. After everyone left I put a beer can on the back stop and worked it back and forth hit it more than I missed From a hundred yards . the red dot makes it to easy I feel like I'm cheating
I'm pretty happy .
						I'm pretty happy .
Re: My latest build
I can't afford nothing like that . I'm probably not agoov enough shot to justify anything like that anyways . kinda like my guitar playingStructo wrote:That's pretty good, I paid around $850 for my Colt around 1994.cbass wrote:I'm new to the AR platform. The amount of choices is pretty overwhelming . I hope I did OK .
Me and my buddy were in the "buy one gun a month club"when I was single, for quite a while..
 I got more like 700 in it now
Re: My latest build
You're not allowed to have an AR15 in Connecticut. Because some mentally deficient individual did a horrible thing with one. If someone with character had one, too, in time, whole different story.
Blame the gun. NSSF is headquartered here. People still gather to protest their existence, because they, gasp, support gun safety.
Somebody shoot me now.
