New to me.
And a $20 bill.
[img
It's a 1951 Heathkit O-7 Oscilloscope. The guy who sold it had previously fired it up and got a horizontal line - I declined to try, didn't want an electrolytic shorting out and nuking the rectifier tubes. Opened it up, the 12AT7 vertical amplifier is cracked. Plus, a ton of bubbly wax and paper condensers, and 64 year old electrolytics.
I'll replace all the caps and the drifty carbon comp resistors. Might install modern BNC connectors for the probes as well, or maybe a pair of binding posts/banana jacks if the existing holes are spaced right.
Anyhow check out these little coil things in the upper right - I'm assuming these are old-school wirewound power resistors and not inductors?. The schematic just has caps & resistors there. The white thing is probably a resistor as well?
[img
Anyhow, complete rebuild in order, then I'll have a cheapo tool to stare at signal shapes. Everything but the potentiometers is getting replaced.
I like how they did the sync circuit in the sweep generator, kind of clever. Maybe that's par for the course for oscilloscopes though, my first time looking at a schematic for one.
One thing I notice is that the metal chassis isn't grounded. I'll have to switch to a three-prong cord for that.
Might paint the case too. Maybe some flames or racing stripes, so it can measure really fast.
