20-Ga Topcoat Pre-Tinned Green PVC Coated Wire 600v
My favorite hookup wire. Last time, I bought from mojotone:
http://www.mojotone.com/amp-parts/ampli ... fW7AXg5nLc
Any alternative places to buy?
Smokebreak
Re: 20-Ga Topcoat Pre-Tinned Green PVC Coated Wire 600v
Post by Smokebreak »
I use the same stuff for general hookup, but 22ga, and get it from valvestorm. http://www.valvestorm.com/Products/Wire
18ga teflon big bottle heaters from Watts or Apex jr , 20ga preamp heaters from the same.
edit : just saw your purdy pics from your latest build, and fwiw the insulation on the VS stuff is not as vibrant
stephenl
Post by stephenl »
We use that in our panel shops sometimes in lieu of ferrules to reduce manufacturing time - nice stuff. I've never tried to solder it though, is the PVC high temp?
For chassis wiring, the max ampacity for copper is:
18g - 16 amps
20g - 11 amps
22g - 7 amps
I've been using 22g tefzel for most everything. I usually run a separate feed for the power tube and preamp tube heaters.
Steve
Leo_Gnardo
Post by Leo_Gnardo »
Only in green? everything looks like a ground wire... fwiw I like some color coding according to function otoh lots of good amps built with single-color insulation so no big deal really.
No, Leo, I do red, green, blue for DC, signal, cathodes. You can do your M&Ms the way you want.
Topcoat wire solders very well. I think it is pre-tinned. The big advantage is that it stays where you put it. The disadvantage is the thickness of the insulation, which really isn't a big deal. Remember, no matter what, it's PVC and it will melt and burn. It isn't PFTE.
