I finally have the finances and time to start gathering parts for my 5E3 build.
 I am, however still stressing over PT and desired/targeted B+ choices. I want this to be as close to authentically original specs as possible, but.... many folks mention that I should go with the lower (660V) PT option, given the higher modern wall voltages, as opposed to the originally specced 710V iron. On the one hand, it sort of makes sense to use the lower voltage unit to help it operate in the manner that it did "back in the day", but I wonder if the unusually high voltage produced by using the original spec PT, with todays higher wall voltage might be what gives the amp the currently supposed "magic" that I hear about. I don't want to build a disappointing turd of an amp!
 I am, however still stressing over PT and desired/targeted B+ choices. I want this to be as close to authentically original specs as possible, but.... many folks mention that I should go with the lower (660V) PT option, given the higher modern wall voltages, as opposed to the originally specced 710V iron. On the one hand, it sort of makes sense to use the lower voltage unit to help it operate in the manner that it did "back in the day", but I wonder if the unusually high voltage produced by using the original spec PT, with todays higher wall voltage might be what gives the amp the currently supposed "magic" that I hear about. I don't want to build a disappointing turd of an amp!All of that being said, I have, of late become a fan of keeping preamp voltage near or at the top of their supposed ranges. Doing this seems to add a little "clarity & definition" to even driven, distorted sounds. Am I on drugs, or what? While I love overdrive and distortion, I dislike mush & mud.
All Help Appreciated,
Gene
 Just joking on that one!
