Hello everybody!
I wonder about Dynaco Ot in Dumble style but what I can find just came with 4kOhm.That's not suite for 4x6l6 right?
Then if I wanna try it,How could I do?
Plein.
						If I wanna try Dynaco Ot on 100watt Bluesmaster?
				Charlie Wilson
Re: If I wanna try Dynaco Ot on 100watt Bluesmaster?
Hello, I believe 2k for 4-6l6 and 4k for 2-6L6. Maybe a 50w Bluesmaster?
CW
						CW
Cw,Charlie Wilson wrote:Hello, I believe 2k for 4-6l6 and 4k for 2-6L6. Maybe a 50w Bluesmaster?
CW
Thanks for reply.that what I understand too.
But just find some from triode that only have 70/120w with 4300ohm.
That mean no dynaco transformer suite for 100watt made,right?
Plein.
Personally, I would choose another transformer over the Dynaco, sticking to the BM baseline of EL34's and Plexi output iron. However, like CW said though, you could build a 2 output tube model.
TM
						TM
TM,ToneMerc wrote:Personally, I would choose another transformer over the Dynaco, sticking to the BM baseline of EL34's and Plexi output iron. However, like CW said though, you could build a 2 output tube model.
TM
Thanks for that too.Actually I use ceriatone bluesmaster kits with plan to modd it.I start the plan with classic tone twin ot(that once use with 102 model and feel good but wanna try something different).
Anyway,It came with 4x6l6.If it go with plexi ot.What do you think compare to twin ot?
P.s. I accidentally work as a guitar maker now.Then I want to make it go along well with strat I made for myself.
Here is the link that my friend ab test it with his guitar.
http://youtube/m_pEeqbrj5Y
Plein.
plysters wrote: But just find some from triode that only have 70/120w with 4300ohm.
Plein.
You know individual taste is all subjective anyway; you could use the Dynaco clone 60/120W OT at 2/4/8 @ around 2.1K, instead of 4/8/16@ 4300.
TM
Tm,ToneMerc wrote:plysters wrote: But just find some from triode that only have 70/120w with 4300ohm.
Plein.
TM
How to use it at 2.1k instead of 4.3?
Plein
Use the speaker taps as 2/4/8 ohm Instead of 4/8/16 ohm
Hello!cbass wrote:Use the speaker taps as 2/4/8 ohm Instead of 4/8/16 ohm
Got it and thank you all!!!
Plein.
