36 watt build - at least it doesn't squeal
power trans
it is 285-0-55vac-285 HT . yes it has the 5 v tap for rectifier I will post pic that came with Transformer
transformer diagram
Here it is I have only really built the 18 watt tremolo`s from Ciara tone lay out adding my own tweaks to it along with the Marshall light single channel amp with good turn out. Still kinda a rookie.
Thank you for quick responce
Thank`s all that have responded any help is much Honored and appreciated...
Re: 36 watt build - at least it doesn't squeal
The HT current rating of 150mA is more like an 18W PT, and won't be enough for a 36W. You need something like an AC30 PT for this, around 270mA... Hammond 290NX or Classic Tone 40-18050.
ok thank you !!! in my 18 watt builds I use the classic tone transformer. I new I should have went that instead of a cheaper USA transformer. Thank you so much!
