Really stupid question
jestaudio
Post by jestaudio »
Been messing with my D Clone, I am ok to just run the preamp section and pull the power tubes if I want to use the preamp section as a standalone for practice? I suspect I should be but am now suffering from severe brain fart :lol:
V2
Re: Really stupid question
Post by V2 »
You won't be able to run your speaker(s) with just the preamp tubes. The preamp feeds into the power amp, then to the speaker - so if you pull the power tubes, no signal will get to the speaker.
jestaudio
Post by jestaudio »
V2 wrote:You won't be able to run your speaker(s) with just the preamp tubes. The preamp feeds into the power amp, then to the speaker - so if you pull the power tubes, no signal will get to the speaker.
That's the general idea, I have a 1 watt power amp that I would like to run rather than the full on roar of 2 6l6 lol, just making sure I don't fry the OT
Meat&Beer
Post by Meat&Beer »
If you pull the power tubes your B+ supply to the preamp will go up. It's not going to sound "the same", you might like that more, you might like that less.
Do you have a dummy load? You'll probably want to go that route if you're looking to jack the preamp into something other than the power amp inside the amplifier itself.
Play your guitar(s)!
