Rivera Preamp scheme???
Fender Amp Discussion
sonofmickel
Post by sonofmickel »
My eyes just bugged out from trying to read the Rivera schemes I found online. I used to have a Knucklehead and the cleans had something going on. I would like to know "why" it was a cool setup. It could get some chimey tones and then could be "gritted" up quite a bit. Lots of flava.
Not really interested in the gain channel, sort of meh...at least for me. I have heard some clips of the Rake that were more to my gain liking though.
Or maybe there is already a clean channel schematic that resembles the Rivera Quiana, Knucklehead etc...?
jaysg
Re: Rivera Preamp scheme???
Post by jaysg »
I sketched the preamp circuits out once, but they're in storage and I can't get at them. If you get the standard knucklehead schematic, print it 11" x 17", you can trace it using highlighters to mark where you've been. The thing is a mess and it's worse to read because he used the +/- 18Vdc heaters...all that daisy chaining.
Each section is relatively straight forward. I believe some of the secret lies in component selection. For example, if you have a mid-60's Fender amp, each tone knob really only has three functional position areas. Riveras have a useful sweep. 2 is different than 3, which is different than 4, and so on.
I believe the reason you can get convincing BF/SF Fender tones from EL-34 output tubes, lies in the subtleties of the output transformer design. He figured out some compromises so he could get a Marshall thump and grit from the other channel.
frankdrebin
Post by frankdrebin »
sonofmickel wrote:My eyes just bugged out from trying to read the Rivera schemes I found online. I used to have a Knucklehead and the cleans had something going on. I would like to know "why" it was a cool setup. It could get some chimey tones and then could be "gritted" up quite a bit. Lots of flava.
this is a Rivera schematic for the R series,it has pretty much all of the classic features of the brand,then tweak to taste.
