Deep switch question
stratcat62
Post by stratcat62 »
I've been playing around with my friend's Ceriatone HRM 100 for a few weeks now and had a question about the affect of the deep switch. Background: I play a Strat - rosewood board, Lollar Special S pickups - which I happen to be loving with this amp. My question is about what the deep switch is doing. When I engage it (up), it seems to kind of CUT the low end, almost enhancing the clarity overall. On the overdrive side, it makes things much more 'singy' and midrange-y. There is substantially more low end and bandwith overall, it seems, with the deep switch OFF. Isn't that backward? I love the way this amp is performing. I just had an interest as this is the opposite of how I understood the deep switch to work before I got the amp. I definitely prefer this amp with the deep switch engaged.
I attached an mp3 below. iPhone voice recorder, so really not the quality it should be. But you can hear what I'm talking about enough to get a feel for it. Any insight is appreciated.
Thanks!
aflynt
Re: Deep switch question
Post by aflynt »
Mine gets darker, more scooped and boomier when engaged. Could the Ceriatone be wired backwards?
-Aaron
Charlie Wilson
Post by Charlie Wilson »
Yeah, it sounds like it is wired backwards. Does that amp have sliders switches or toggles? I looked at the Ceriatone layout and the switches are wired upside down of the deep switch for the Low Plate Classic on this forum.
CW
My Ceriatone BM HRM 100w does the same thing deep is in off position.
jam-mill
Post by jam-mill »
@Moderator,
I had already started a topic about deep switch wiring discrepancies; perhaps this topic should be merged with it to keep the information in one place?
@all,
Yes, the deep switch for a Ceriatone OTS does seem to be wired backwards, but what does it really matter?
Also, isn't 'down' the engaged or 'on' position for the bright cap? If so, seems like the 'deep' should operate similarly. My 2p.
-jack
Up is bright engaged.
Charlie Wilson
I suspect that Ceriatone used the wiring for slider switches which are the opposite of toggle switches as a guide for their layout. If this is the case, they should have corrected that as most people are using toggles. Below is a photo of how HAD did it. I just noticed that the 270k resistor coming off my deep switch is going to the wrong terminal on the Jazz/Rock switch as is the one is on Tony's LPC layout. This doesn't matter unless you engage the deep and Jazz at the same time.
CW
jam-mill
Post by jam-mill »
Sure makes sense to have the resistor that goes to ground closer to the bus bar; same thing with the cap on the J/R switch.
On these miniature switches you use the lugs that are opposite of the direction the toggle bat swings and whether tubes up or tubes down.
Remember that when soldering and you will wire the switches correctly every time. Of course with these Dumble circuits there is a lot more going on.
Charlie Wilson
Here they are on sliders.
CW
jam-mill
Post by jam-mill »
@CW - where is the source of the pictures?
Charlie Wilson
These are Dumbles I have been inside. If I say anymore, I will catch some bad karma. :)
CW
jam-mill
Post by jam-mill »
@CW - sorry, don't want you to get into any trouble. Thank-You for sharing those pictures.
Charlie Wilson
No worries. I have not had any rocks(or stale doughnuts) thrown through my window because of the Tweedle Dee expose but I don't want to push my luck. :D
CW
Aaron
Post by Aaron »
Nice pic Charlie, thanks.
It looks like the cap value is .047uf on Rock/Jazz switch?
Thanks,
Aaron
