Just noticed that the Vintage Power transformer that i harvested from an old Tube PA amp  that i want to use for my JCM build, doesn't have a center tap on the B+ windings.
That being said, can I just connect the windings to the middle of the 4 diodes, then ground the ends to make a bridge rectifier? instead of the 2 phase Full wave?
						JCM800 With Bridge Rectifier
- pleasantbullet
Re: JCM800 With Bridge Rectifier
Yes you can!
But...you may not get the B+ voltage that you originally sought with a full wave, CT approach.
What is the un-loaded AC voltage across the secondary?
Dave O.
Dave O.
- pleasantbullet
I measured 400 volts AC.
						- pleasantbullet
now that i think of this in more detail
400 VAC @ approximately 1.3 times is 520V, should i consider adding a power resistor to knock that down some?
If so, what size should it be and how many watts should it be rated for?
You might change those rectos out for a fast recovery type which will take noise hash out of the power supply which is what you are listening to all along any way!
]You might change those rectos out for a fast recovery type which will take noise hash out of the power supply which is what you are listening to all along any way, the power supply!
