Hi,
I've been a long time reader here.
I want to build a d-lite 22 and in researching sources for parts I think to most challenging parts to find will be the chassis and boards for the pre-amp and PS sections.
Can someone to me where I can source these? And are there any mechanical drawings with specs/dimensions for this amp anywhere.
Thanks in advance.
						New Build D-lite 22.... where to source chassis and boards?
- longislandrod
Re: New Build D-lite 22.... where to source chassis and boards?
Unless there is some miracle that you can obtain a chassis and board set from Brownnote you are going to have to roll your own. In all honestly its easier to just get an ODS style chassis, board set  from Marsh or either Ceriatone and build up 6V6 pair unit from that option.
I can get you the board dimensions off a BN set I have if you want.
TM
TM
Rod, check your PM for a holiday miracle...ToneMerc wrote:Unless there is some miracle that you can obtain a chassis and board set from Brownnote you are going to have to roll your own.
				Salvovulcan
brown note
[quote="ToneMerc"]Unless there is some miracle that you can obtain a chassis and board set from Brownnote
Hello, sorry for the question but considering that I'going to send money to brown note to get a kit, what do you mean with "Unless there is some miracle that you can obtain a chassis and board set from Brownnote "??
Rod has decided to wait for his build. I have a kit available.Zippy wrote:Rod, check your PM for a holiday miracle...ToneMerc wrote:Unless there is some miracle that you can obtain a chassis and board set from Brownnote you are going to have to roll your own.
Please contact me for details.
I see the Brown Note amps website has been updated 2015 and includes a lot of new amps/options I have not seen before but the forum is down.
So that must mean these guys are getting their kits or able to order them?
A month ago or so I inquired and had some email back-and-forth about a chassis and some transformers. Ultimately BN didn't have the transformer set I wanted in stock. I think I was looking for a 22/44 switcher and they had only the 44W, but there were chassis and 44W sets available. Events ensued and I ended up buying something else for my build (not a 22/44 switcher) but I was led to believe there are things available.M Fowler wrote:I see the Brown Note amps website has been updated 2015 and includes a lot of new amps/options I have not seen before but the forum is down.
