Rather than use switches when I'm tuning a new amp, I just put in extra turrets for two anode resistors in series (I usually start with a 50k in series with a 100k), and the same for the cathode resistors (starting with two 820R resistors in series), along with 1uF and 22uF bypass caps that are left open at one end, so either one (or none)can be jumpered into the circuit.
Then I can quickly switch between several combinations using short Pomona jumper clips.
This keeps the wires short, and I don't have to drill extra holes in the chassis for switches.
When I get the sound I want, I just re-do the board without the extra components. You can even use this method to jump across entire gain stages or to switch global NFB in and out, among other things.
I've found this useful because in the time it takes to switch a component or two, my aging brain can't remember what it sounded like before I changed it
