Check this Flocking stuff out!
Re: Check this Flocking stuff out!
Yeah, flocking. What about it? It's been around since at least the 19th century.  It's like powdered velvet that you pour over adhesive. They use it on wall paper, but it isn't in style right now AFAIK.
Well, seems I don't know what's in style. Get some at Target:
http://www.target.com/p/elizabeth-doubl ... oCQaXw_wcB
You can always leave something on the (outside) top of your kitchen cabinets for about 10 years, it will develop an interesting flocking
				vibratoking
Act fast, limited quantities.
Looks like garbage.
									Looks like garbage.
vibratoking wrote:Act fast, limited quantities.
Looks like garbage.
Yup, it' s a flocking shame.
Mike
Sunnydaze
				beasleybodyshop
It was a real hot fad in 1972 for about two weeks - They used to flock cars and hot rods with it. Ugh. Ever try to sand that shit off a International Scout? It's murder.
FWIW Hughes and Kettner used it extensively on their Guitar and Bass Combos.
Problem is that they applied it so well that ebverybody thinks it's carpet.
Traynor also used it on some of their PA equipment.
EDIT: H&K Attax40 & 100
Looks like carpet but see there's absolutely not cuts or joints, specially on corners or the back panel.
It's impressive how protector less corners survive the road.
[img 768]http://medias.audiofanzine.com/images/n ... -17894.jpg[/img]
[img 1424]http://medias.audiofanzine.com/images/n ... 386123.jpg[/img]
It's not the same as "suede" but closer to plush.
[img
[img
It could probably be made to be durable by spraying some lacquer or poly over it.   Maybe that's what H&K did.
mike
									mike
Sunnydaze
So, it's gorilla hair??
We used to flock our Christmas trees.
And, you must have a color wheel to complete the look.
[img::]http://www.meijer.com/assets/product_im ... _A_400.jpg[/img]
[img:433:480]http://media-cache-ak0.pinimg.com/736x/ ... 41d427.jpg[/img]
Looks great... until you want to do a quick speaker swap.JMFahey wrote:Looks like carpet but see there's absolutely not cuts or joints, specially on corners or the back panel.
[img1424]http://medias.audiofanzine.com/images/n ... 386123.jpg[/img]
That speaker is front mountedZippy wrote:Looks great... until you want to do a quick speaker swap.JMFahey wrote:Looks like carpet but see there's absolutely not cuts or joints, specially on corners or the back panel.
Just remove the front metal grill and replace it.
No need to pull the (glued) back panel at all.
To do flocking right, you have to have a good electro-static setup. You need to get the fibers standing on end while applying.
It ain't easy to do it right or cheap. And I couldn't imagine ever looking good on anything but a puppet. Used to have to flock things for stop-motion animation projects...but it was far easier to just send it off to Hensen Creature Shop and get it done right.
