superdrive mod
superdrive mod
Surely someones already done this along time ago on a Marshall or something but
I noticed several of you built the sd60. I tried this on my 100 watt version.
You have to use a stereo input jack for your high input or cliff type with a switch on the sleeve.
I decided the low input sounded much better with a bigger cathode bypass cap but I dididnt like the bigger cap when using the high input. So I wired a .68 uf in parallel with the stock .1uf except I grounded the end of the .68 cap to the switch of the high input jack. So I have the stock .1 when I plug into the high and .78uf when I plug into the low.
Re: superdrive mod
Give yourself some credit. That's bloody brilliant.
Re: superdrive mod
(deleted)
Re: superdrive mod
You have to use a stereo input jack and use the the unused terminal to switch the .68
Schematicus
http://music-electronics-forum.com/atta ... -image.jpg
It definitely sounds better with the bigger cap on the low input IMO it was barley usable with .1 bypass cap
Schematicus
Smokebreak
Re: superdrive mod
Great idea! Save a switch!
Re: superdrive mod
I edited my posts I didn't even have it hooked up like first described. I probably shouldn't even be working on amps now or driving or using power tools.
Anyway It will take a stereo input jack for this mod
Re: superdrive mod
What a minute I think it will work with a normal ass cliff switching jack. Dammit I just wired up a stereo jack and it was a huge pain in the ass my brain is frazzled . Id like to say fuck it and go get real drunk.
Smokebreak
Re: superdrive mod
I think if you just hook it to the ground switching lug on a cliff type(on the Hi) it will work.
Re: superdrive mod
(deleted)
Re: superdrive mod
Yes you're right I think that's how I had it wired to begin with my thoughts and actual words don't always coincide . its been a long couple of monthsSmokebreak wrote:I think if you just hook it to the ground switching lug on a cliff type(on the Hi) it will work.
- dorrisant
Re: superdrive mod
Dude, Great idea!
I'm guessing the next step would be to use that switch to feed the coil of a relay...?
- dorrisant
Re: superdrive mod
Double post
Re: superdrive mod
Bear in mind that as the guitar lead is being inserted into that socket, the tip will be momentarily connected to the 'ring' connection used for the switching action.
So it may be bad practice to use this method for any substantial voltage / current switching, which might include a relay coil.
The Fender type jack socket with an isolated DPDT switch would be fine though for such a function http://www.hotroxuk.com/fender-pc-mount ... bj107.html
