Speaker suggestion for a Marshall combo build
bcmatt
Re: Speaker suggestion for a Marshall combo build
Post by bcmatt »
I think that if you like the Veteran 30, you will like the Retro 30 even more. It is similar in style, but it is a bit more open sounding and bright. It's a bit smoother (fixing a bit of amp raspiness that came through with Veteran 30s for one of my amps). Also, it has a bit more of a bold muscular tone, that still sounds pretty big in a 1x12 open back cab compared to the Vet30.
The ET-65 I also like, but it is more even sounding and more muffled in the highs than either of those speakers. It is smooth as well. I'd say it's a very versatile speaker that sounds quite good with pretty much any amp. Great for taming a JCM800 with too much high end harshness.
Creambacks are sweet, but about twice the price of these. Sounds to me like you are looking for a Retro 30 though.
Alan0354
Post by Alan0354 »
bcmatt wrote:I think that if you like the Veteran 30, you will like the Retro 30 even more. It is similar in style, but it is a bit more open sounding and bright. It's a bit smoother (fixing a bit of amp raspiness that came through with Veteran 30s for one of my amps). Also, it has a bit more of a bold muscular tone, that still sounds pretty big in a 1x12 open back cab compared to the Vet30.
Thanks for the detail reply, my question is whether the Retro 30 is different enough from the Veteran 30.
bcmatt
Post by bcmatt »
Yes, it is different enough that I would say my Liverpool sounds "good with the Retro 30 but "bad" with the Veteran 30.
Alan0354
Post by Alan0354 »
bcmatt wrote: Yes, it is different enough that I would say my Liverpool sounds "good with the Retro 30 but "bad" with the Veteran 30.
Thanks,
Also, do you have any experience with ET90? I listened to a video comparing with ET65, seems like ET90 has more of the upper mid that gives better sounding in OD.
bcmatt
Post by bcmatt »
Thanks,
No. Sorry. Haven't tried one.
I have had both the Veteran 30 and Retro 30 and I was under the impression the Retro 30 is slightly brighter then the Veteran 30.
