Simple buffered effects loop
jestaudio
Re: Simple buffered effects loop
Post by jestaudio »
martin manning wrote:Great! Do you have a return level pot? Merlin suggests a 100k, but it probably isn't too critical. FWIW, I would make the input divider 910k and 33k to get unity gain through the loop when nothing is plugged in.
The only mini pots i have to hand now are a 220k and a 1 meg, I assume you are referring to the 1 meg/15k arrangement that I screwed up lol,
Like this: (with a little edit for clarity showing that using the return jack breaks the connection from the driver to the recovery stage)
Last edited by martin manning on Sun Sep 14, 2014 11:05 am, edited 1 time in total.
jestaudio
Post by jestaudio »
martin manning wrote:Like this:
Got it , will have a play tomorrow, its late and I don't want to piss my drum playing neighbour :D
Smitty
Hmm?
Post by Smitty »
I believe that's the first time I've actually seen a drawing on the back of an envelope.
David Root
Post by David Root »
I've always used Normster's '97 buffered loop, send is a CF, return a grounded cathode. Both use 250k audio pots. I don't use the brightness switches, doesn't need them. And no I don't use Xicon caps either, I use the Solen poly propylene 630V, they actually fit the available space.
I built a real Dumblelator with the bright switches & I don't use those either, but I used 11 pF/ft video coax on that one.
Re: Hmm?
Smitty wrote:I believe that's the first time I've actually seen a drawing on the back of an envelope.
Just making good on a previous threat: https://tubeamparchive.com/viewtopic.ph ... 950#286950
jestaudio
Post by jestaudio »
Well success, I have a working useable loop, only a send level fitted due to space but works very nicely with my floor based effects, cheers to all those who chimed in
Colossal
Re: Hmm?
Post by Colossal »
Smitty wrote:I believe that's the first time I've actually seen a drawing on the back of an envelop.
All of the best work is done there :wink:
Shouldn't the voltage on the cathode follower be about 30v?
