UR12 wrote:Do I have you completely confused yet?
Yes
UR12 wrote: On the second triode you basically have the grid tied to AC ground through the cap from the grid to the cathode and the top of the bias resistor.
As a common reference, am looking at Dr. Hulsey's schemo numbers.  Which cap do you mean?  C10 and/or C11?  Top of the bias resistor as in the junction of the 4 resistors (long-tail) or as in where it connects to the cathodes?
UR12 wrote:
This sets up the stage kind of like a grounded grid amplifier. Remember in a cathode follower circuit where the output is taken from the cathode the signal remains in phase with the input signal.
You saying that the first triode can also be treated like a cathode follower?
UR12 wrote:The second triode’s signal input is actually the signal being developed across the tail resistor from the first triode and since it is also connected to the second triodes cathode, the signal on the cathode is the input to the second triode and the output is taken off the plate and is in phase with the signal being applied to the grid of the first triode. Grounded grid amplifiers do not change the phase of the signal applied either.
Let me see if I got this straight.  Probably some holes, but here's a shot:
Assume signal input is rising (going positive).
Input signal going positive causes the Triode 1 (T1) grid voltage to increase.  This decreases grid bias, which results in increased T1 cathode to T1 plate current.  As stated, the output is inverted when measured at the plate resistor (R15).
When T1 cathode to plate current increases, current throught the bias resistor (R13) increases, resulting in an increase of voltage across R13.  This increases the T1 grid bias?  Normally, this would then result in a decrease in T1 cathode to T1 plate current.  I can only assume that this increasing grid bias just retards (a bit) the T1 grid to plate current increase, not completely reversing it?  The input signal is great enough to overcome this tendency?
Since this is a shared bias resistor, it directly affects Triode 2 (T2).
As above, the voltage across R13 bias resistor is going increasingly positive.  This increases the T2 grid bias, which causes a corresponding decrease in the T2 cathode to T2 plate current (since there is no direct input signal as with T1, there is nothing to keep it from dropping?)
Measuring off the 100k plate resistor results in an increasing signal (at this point, it still inverts.) , which is "in phase" with the PI's input signal.
All these voltages are scaled/phased versions of the input signal.
This in the ballpark?  Or up in the stands behind home plate? LOL.
