HEad cabs available
- Funkalicousgroove
HEad cabs available
Hey all,
I have 8 head cabs available, 5 black/black, 3 Rough blonde/oxblood.
The cab guy built them a bit too tall, and I don't want them. He's looking to move them quick @ $125ea send me a pm if you are interested, they fit my chassis.
						Re: HEad cabs available
PM sent!
PM'd
D
						D
Got a pic (or something close)? Are they complete with feet & handle? Is there a back cover?
				tele_player
PM'd, I'm good for 1,2 or 3.
						- RJ Guitars
Funk,
Can I have some dimensions? I need something that will accomodate a 19.25 x 7.75 x 2 inch chassis
rj
rj
http://www.rjguitars.net
the front to back dimension is 10" a little too deep for your chassis - the other measurements are about right.
www.RedPlateAmps.com
- Funkalicousgroove
THe cabs are 100% complete, you just need to mount the aluminum strip, which I will include because I am such a fine fellow
They are set up for my chassis and have mounting holes pre-drilled, you just have to find them under the tolex!!
It is best to mount your chassis before you fit the aluminum strip, then remove your chassis before you screw the strip down.
You can use #4 or #6 countersink wood screws to hold the strip down.
They are 10" deep, 10 3/8" tall and 20 3/4"(give or take) wide.
My chassis is only 19", the other 1/4" makes room for tolex, and a bit of wiggle room(like the real ones).
The cabs are the same as the pics of amps on my site www.bludotone.com
						- Funkalicousgroove
RJ,
my chassis are 2.5" tall, so you'd have a half an inch gap to fill.
If you want to modify one I have one out of an older batch that you can have for $85 + s&H, but it will require much modification. It is rough blonde/oxblood.
				tele_player
How much 'a bit too tall' are these cabs? Are they 10-3/8", or is that the dimension you really wanted them to be?
						- Funkalicousgroove
they were supposed to be 10 x 10, they came to me at 10 3/8 x 10.
Horrors!Funkalicousgroove wrote:they were supposed to be 10 x 10, they came to me at 10 3/8 x 10.
- Funkalicousgroove
I get that it's not that big of a deal,  but it's also not what I ordered, and not the first time it's happened, and not the only issue I've had.  This was just the straw that broke the camel's back!
						- Funkalicousgroove
The cabs are all gone fellas,   I am placing an order for some really sweet ones that will be about $230.00  in your choice of colors, or around $500 for your choice of suede.
if you want to get in on one delivery time is about 45 days.
