[img:777:580]http://shrani.si/f/32/eL/4MQbXBFy/jtm452.jpg[/img]
[img:777:580]http://shrani.si/f/2U/RZ/EoardwN/jtm451.jpg[/img]
This JTM45 has split chathode network on V1, 500k bass pot, push/pull pot on normal channel (bright cap), 0.068uF instead of 0.1uF on PI and HUGE custom built toroidal transformers.
OT has 7k5 primary impedance... and what is interesting when I measured DC resistance across primary taps it was 94ohms on both sides.... I mean within 1ohm difference. Usually you don't see this on the OTs.
