bass cap in the late 90 amps
Hi, please what is the correct value for the bass cap in the late 90 amps?everybody is talking about .1bass cap but to me sounds better .022 with the .01 mid cap with .047 at the output of the clean channel.THANKS
						- Funkalicousgroove
Re: bass cap in the late 90 amps
.1 for HRM,  .02 for bass and Mid for bluesmaster.  .05 coupler for HRM, .01 coupler for Bluesmaster.
THANKS FUNK,are you using a .01 mid cap?i know some 80's amps had .015mid cap,using .1 bass cap and .01 coupler it's a great Stevie Ray thing
You've seen a .015uf midcap??    Just checkin'...
						pazzo63 wrote:THANKS FUNK,are you using a .01 mid cap?i know some 80's amps had .015mid cap,using .1 bass cap and .01 coupler it's a great Stevie Ray thing
Hi Scott,no i did not see that but i have some serious informations try that one but you probably already did that..  ot does sound like Robben in the 80's very fenderish but not fender,sorry...very Stevie Ray..
						- Funkalicousgroove
Never seen a .015,  I kinda like .02 myself, kind of a  Super reverb vibe.
That's right!i would suspect that Mr Dumble used different values only for some great people...
						- Funkalicousgroove
I'd suspect that if you were someone who got your amp tuned in "His" presence, you could have ended up with all kinds of different parts.
