'66 Ampeg Reverberocket II can cap question
- gui_tarzan
So this model has a can with a 70/40/40 @ 450v and the closest replacement I can find is an 80/40/30/20 (525v). I'm not concerned about the 80uf section, but if I use the 30uf section in place of the second 40uf is that going to be enough for the last stage of the power supply in this amp? My gut says yes due to very loose tolerances in caps but I just wanted to double-check.
									--Jim
Re: '66 Ampeg Reverberocket II can cap question
Sure, no problem.
				Invertiguy
Most electrolytic caps are +50/-20% tolerance anyway, so 30uf isn't really that far out of spec. If you're still concerned, you could always put the 30uf and 20uf sections in parallel to get a 50uf cap, which is more than enough.
						- gui_tarzan
Yeah, I thought about that. Thanks guys, I figure it's better to ask than do something stupid and cause more problems.
--Jim
- Leo_Gnardo
If your replacement is CE make plans to replace it again soon come, and then again. I'm not much for playing idiot's delight with CE multisection caps and even moreso considering their high prices. I put in 50+50/500V cans (Ruby, F&T, LCR, JJ) and fly another 47/500 axial in there to cover the 3rd section. Needs a clamp for the 50+50 cap. I've done scores of old Ampegs like this and nary a failure.gui_tarzan wrote:So this model has a can with a 70/40/40 @ 450v and the closest replacement I can find is an 80/40/30/20 (525v). I'm not concerned about the 80uf section, but if I use the 30uf section in place of the second 40uf is that going to be enough for the last stage of the power supply in this amp? My gut says yes due to very loose tolerances in caps but I just wanted to double-check.
Good thing these are / where not high gain amps, as the can cap / all circuits grounded to the same point thing makes for un-needed hum.
When I do these amps for a customer that plays the darn thing I put in all separate caps and leave the shot stocker hanging there for looks, just not hooked up of course!
- Leo_Gnardo
In 60's Ampegs, besides the multisection typically there are a couple of single caps filtering the preamp feeds. Old Ampegs are notorious for imperfect grounding schemes - I've spent many an hour optimizing some especially for customers who play quiet jazz and can't stand buzzes in their amp. It CAN be done, and the old trick of bringing the last filter's negative lead to ground near the input circuit seems to help.Stevem wrote:Good thing these are / where not high gain amps, as the can cap / all circuits grounded to the same point thing makes for un-needed hum.
Haven't had an Ampeg customer yet who complained about their silver cylinder being replaced with a black, blue or any other color one. OTOH Fender owners seem to have a different attitude sometimes - for Champ and Princeton I often leave the original in place & fly a collection of singles in right over it inside the chassis.
						- gui_tarzan
That's something to consider as well.
									--Jim
				RightLurker
If it's of interest, Fliptops.com specializes in Ampeg parts and has the correct replacement can cap.  I think it costs around $38.  Based on my experience, they are great to work with.
						- gui_tarzan
Thanks but it says the domain is for sale.
--Jim
If your model rocket has the 6U10 tube in it, I would get some NOS spares while they can be had!
It's http://www.fliptops.net/gui_tarzan wrote:Thanks but it says the domain is for sale.
- gui_tarzan
That's better. Thanks!
									--Jim
