Filter bypass
Filter bypass
Post by Stevem »
Some whats the consensus on adding lets say a .22 uf and a .022 uf caps in the power supply.
Add them on the main filter only?, on the last preamp filter?, or both the first and last filter?
Seems some in the HI Fi crowd use a .68uf and a .01uf.
Jana
Re: Filter bypass
Post by Jana »
I usually put a .022uf on the first preamp filter node. That, along with UF diodes helps create a very clear sounding amp (provided everything else is done right).
I don't put the caps on all the nodes--it gets too hi fi sounding.
What?
gui_tarzan
Re: Filter bypass
Post by gui_tarzan »
Where are you putting these? Can you show me a diagram? I'm still very green when it comes to the design & theory part of amps.
--Jim
Re: Filter bypass
Post by Stevem »
Across a power supply filter so the chosen cap(s) your adding must be rated for at least the dc voltage seen across the filter you are adding it to.
Synchu
Re: Filter bypass
Post by Synchu »
That would be in parallel to the filter electrolytic.
My brother got me to build him a hi-fi tube amp that I am just finishing - the PS is PITA :)
[img:500:500]https://farm8.staticflickr.com/7003/13361139645_4b3b5729f8.jpg[/img]
gui_tarzan
Re: Filter bypass
Yeah, that's a lot more complex than my Fender filter cap boards. Is the smaller one at the top in the middle the one you're talking about? I was hoping more for a drawing, it's impossible to see where that's connected in that pic. That is a lot of filtering. And are you talking about using the UF diodes at the PT secondary or somewhere else?
--Jim
Synchu
Re: Filter bypass
Post by Synchu »
See the schematic here:
http://diyaudioprojects.com/Tubes/EL84- ... matics.png
The 0.1uF film caps are wired in parallel to the 100uF electrolytics (little black caps protruding between the F&T electrolytics on the picture).
Gibsonman63
Re: Filter bypass
Post by Gibsonman63 »
I'll show my ignorance as well. What are we trying to accomplish with the smaller bypass cap?
rp
Re: Filter bypass
Post by rp »
The Hifi builders do this. IIRC it's a 1000 (100?) to 1 ratio, something about them resonating if the bypass is too big. If you google this you will get a ton of DIY hifi talk about it - mostly very positive but it's a different universe. I've avoided it as the guitar guys talk bad about it, but it never occurred to me to try just one stage and the pre at that. Thanks for bringing that up. It's so easy to do I think next time I break open an amp I'll try it.
Might be a good way to find a little extra brightness in a dark amp w/o messing with a good tone circuit. Hmm, maybe I'll crack open my 5F1.
BTW people stack the bypasses too i.e.: 100 - .1 - .01 - .001, seems nutty. They bypass the cathode bypass caps too. Hmm, 5F1 again? Anyone try this? Does it skew the tone weird?
gui_tarzan
Re: Filter bypass
Ok, now it makes sense. It seems redundant but I guess if it works...
--Jim
Jana
Re: Filter bypass
Post by Jana »
This probably won't make a dark amp brighter. It is more about clarity. If it is a dark amp, it will be just a little bit clearer dark amp--if that makes sense. Put another way, it's not like adding a treble peaking cap across a resistor or adding a bright cap to a pot--it is just a clearer sound. From my experience, the overall frequency character of the amp doesn't change.
What?
Jana
Re: Filter bypass
Post by Jana »
It's not redundant. It has to do with the ESR of caps.
What?
JoeCon
Re: Filter bypass
Post by JoeCon »
So Jana
You're talking about "noise" cleaner not distortion vs clean sound, right?
So if your amp is dark or bright this will not clean that up but make the tone you already have clearer. Interesting....
Thanks...
rp
Re: Filter bypass
Post by rp »
Jana wrote:It's not redundant. It has to do with the ESR of caps.
Right, and part of the spiel of hot shit super caps like Black Gates was that they were so low ESR and so good they could go un-bypassed.
Jana
Re: Filter bypass
Post by Jana »
RP, not sure how to take your post--are you saying I'm full of shit?
What?
