Fender used a 6K6 impedance for the Deluxe OT. It didn't have a 4 ohm speaker tap but just a tap paralleled with the 8 ohm tap. So, if you plugged in an 8 ohm extension speaker, the OT impedance is 3K3. This is much lower than the design recommendations but it seemed to work. Did the tubes handle this over the long run?
You may have seen my JTM 15 thread. I have a Deluxe 6K6 OT in the amp. I was playing it this morning and decided to switch it to the 16 ohm tap with an 8 ohm speaker load to simulate the 3K3 load mentioned above. Oh my, I like it much better. The bass is tighter. The amp seems to take on a different character, which I like. Granted, this is at low volume levels.
What gives? Is this a disaster waiting to happen? I've never owned a real Deluxe so I don't have any experience with the long term effects of this (on tubes and the amp).
I'm thinking of changing the PT in this amp to drop the B+ to about 360 volts. I'm also considering putting in an OT with a 4200 ohm impedance. Am I crazy? (relative to this idea, not life in general--we already know the answer to that).
