Possible production run of circuit boards
Re: Possible production run of circuit boards
I'd like 1 set of boards and an x-former for Dumbleator - please!
Any options are at least a few weeks out. I have a sample in production of a replica of the original Triad unit used in the Dumbleators. It's the same specs/dimensions and would mount on the rear of a single space enclosure. Price would be around $30 depending on the total order and the shipping costs to me. I could also look at a smaller unit, but many in the group likes to be historically accurate with the layouts. PCBs are not an issue and could be done in a couple of weeks once we decide on what transformer to use.trane34 wrote:Any news on the d lator set?
http://agbamplifiers.com/
Dumble Clone Circuit Boards
You are doing a great job!
I think there are some that would like the vintage look with the transformer on the back wall, protruding out the back.
But if I was to re-design the Dumbleator, I would make the transformer so it would fit inside the enclosure, since that is more germain to modern UL and CE listing.
Functionally, it doesn't matter but if you want to keep current of the rules then it should go inside.
