Tubedepot Tweed Champ kit
Zippy
Re: Tubedepot Tweed Champ kit
Post by Zippy »
The cathode resistor on the 6V6 should be the 3W, 470 ohm resistor.
Maybe there is some color shift in the image but that doesn't look right - should be yellow-violet-brown.
I may be slow to build but I always check the value of each resistor with an ohmmeter before putting it in the circuit. I make up that time by not having to trouble shoot new builds as much.
The New Steve H
Post by The New Steve H »
I called him and explained that in order to provide you with good information, he needs really tight shots, and that he should post all sorts of voltage measurements. He is going to work on that. I also told him to check things with a meter instead of relying on the values on the components.
The resistor in question is supposed to be 470, and he is getting .470 on the meter. Whether he's using the meter right is another issue.
Relax. It's SUPPOSED to smoke a little.
Vectorer
Resistor
Post by Vectorer »
Thanks Zippy. I am definitely going to check that resistor.
Vectorer
new to the board
Post by Vectorer »
I thank you in advance for being patient and helpful. Since I am new to this type of forum my learning curve as to how best ask for help is steep right now.
Zippy
Post by Zippy »
The New Steve H wrote:I called him and explained that in order to provide you with good information, he needs really tight shots, and that he should post all sorts of voltage measurements. He is going to work on that. I also told him to check things with a meter instead of relying on the values on the components.
470 = .470k
It could work... :lol:
Thanks for checking in with him, Steve.
This is a nice lil' community.
The New Steve H
I haven't seen the meter. He says it's auto-ranging. Now that I think about it, .470 ohms would be a bit on the low side, since it's not all that far from the resistance of a piece of wire.
Not if its really 0.470k ohms.
The New Steve H
He couldn't find a 470 ohm resistor at Radio Shack, but they had a 500. I told him to buy it and meter it. If the meter says .500, then the resistor that came with the kit is correct, and now we know how to read the meter.
ToneMerc
Post by ToneMerc »
Sounds right, many DMM's will read in reference to 1K, so .470 would be correct for a 470R.
Steve H, where have you been hiding buddy.
TM
The New Steve H
I had my latest amp ready to go last year, and I started putting components on the board. Then I realized I had drilled a mirror image of the correct board.
I put it down, forgot about it, got back into machining...
It would take me like two days to get that amp running. I better do it.
The New Steve H wrote:I had my latest amp ready to go last year, and I started putting components on the board. Then I realized I had drilled a mirror image of the correct board.
The board is ok- it's not a mirror image until you install the eyelets/turrets.
The New Steve H
Well, I wouldn't have stuck components on it without the turrets in place.
Vectorer
Hi-Res pics A
Post by Vectorer »
Hopefully these are more useful.
Vectorer
Hi-Res Pics B
Post by Vectorer »
...more
Vectorer
Hi-Res pics C
Post by Vectorer »
...more
