Shoot me...
Shoot me...
if I ever show signs of entering the marketing profession.
http://www.mercurymagnetics.com/pages/c ... ord-01.htm
Re: Shoot me...
Don't forget to upgrade all of your amp's internal wiring to at least 14AWG as well. If you don't, all those free-flowing electrons will stack up at the power switch and cause an arc!
- VacuumVoodoo
Re: Shoot me...
[img:137:85]http://i26.photobucket.com/albums/c149/ ... 086-10.gif[/img]
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
Zagray!-review
Re: Shoot me...
I wrote semi-nonsense words like these for decades. Not so silly, I hope.
I don't mind the fat wire claims as much as the digital ones: "My bits are better than their bits."
Re: Shoot me...
My favorites are the arc welder size speaker cables, a few feet of fat copper speaker cable (in the case of tube amps) coming off a few hundred feet of transformer secondary going to a few hundred feet of usually aluminum voice coil.
Re: Shoot me...
You're not cool unless you have one of these
http://essentialsound.com/product/Essence_Cord.html
Re: Shoot me...
Personally, I like my snake oil in hardwood puck shape. Here, but this under your amplifier, and everything will sound more present!
Re: Shoot me...
Yeah, it says, "The More You Buy, The More You Save!" and "Shipping Weight: 3.00 pounds"cbass wrote:You're not cool unless you have one of these
Re: Shoot me...
You don't think a power cord can make any noticeable change?
Most of you know a guitar cord can.
Then you probably believe all resistors sound the same, and all caps sound the same.
EtherealWidow
Re: Shoot me...
Amateurs
My favorite is the $500 knob.
EtherealWidow
Re: Shoot me...
At $1,000 a meter, you need to save somehow.Phil_S wrote:Yeah, it says, "The More You Buy, The More You Save!" and "Shipping Weight: 3.00 pounds"cbass wrote:You're not cool unless you have one of these
Re: Shoot me...
Beefs up your amp's power supply
Makes your amp sound bigger
Improves your amp's touch-sensitivity
Tightens your bottom end
Really?
Really?
Re: Shoot me...
A chain is only as strong as the weakest link.
- Reeltarded
Re: Shoot me...
I use wireless. My amp is down at the substation.
FREE ELECTRON!!
FREE ELECTRON!!
- Leo_Gnardo
Re: Shoot me...
Some do. Many don't.Cantplay wrote:You don't think a power cord can make any noticeable change?
There are a few things that produce a real improvement.
And a LOT of spurious rubbish sold by those who want to make a buck on those who are looking for that real improvement but 1) think they're going to save money by buying the slightly cheaper (or sometimes more expensive) version and B) need to show how cool they are by buying the ersatz = emperor's new clothes all over again and again and. . . . .
Personally I've never detected an audio improvement due to power cord replacement, other than making an item power up that had a defective cable... but then again I'm not in position to audition cables that cost hundreds or thousands of dollars. The argument has been made, and I think it's accurate, that there's a long skinny "extension cord" between your outlet and the "pole pig" transformer. If you invest in one of the super dooper AC cables and genuinely believe you hear an improvement, who am I to argue?
With guitar cables, caps, resistors, iron, pickups, wood, yeah I agree with you, definitely, quality levels are evident.
Amusing reading recently, an EV manual for a powered mixer, recommending the user NOT use coily guitar cords to connect to speakers. Yes, that would be bad... real bad.
