Latching Relay Switching
JazzGuitarGimp
Re: Easier?
Post by JazzGuitarGimp »
ampdoc1 wrote:While the info contained in the above posts will surely work, I like simplicity!
In looking for options to use on a new build, I ran across these! There are other configurations available, but the combination of NO+NC controls on a single chip looks ideal for amp use. Also, they are no more expensive than standard relays. And, I have found a simple 6VDC supply with a dropping resistor to the LED control pins works well.
a'doc1
This looks like a nice solution, if it weren't for the price. You need two of these to implement a DPDT relay. At Mouser's pricing, that will set you back $10.82. I am fond of the ADG333A, which is a quad SPDT analog switch (two DPDT relays) which still isn't cheap at $6.57 (Digi-Key). But you'd need four of the Optomos relays to do what this chip does, so $21.64 vs. $6.57.
ampdoc1
Price
Post by ampdoc1 »
Can't argue the price. But I'd rather spend the money for that relay and a DIP socket than spend the time to piece together a half dozen components
(per relay) to achieve the same thing. I value the simplicity! And in the totality of costs to build an amp, the percentage of additional $$ to go this route would be very small.
But, each of us on this site do things differently, and trade ideas. I was only suggesting another way to go!
Everyone have fun!
JazzGuitarGimp
Re: Price
ampdoc1 wrote:Can't argue the price. But I'd rather spend the money for that relay and a DIP socket than spend the time to piece together a half dozen components
Everyone have fun!
And to be fair, my point of reference for price is some stomp box designs I've done recently. Compared to amp building, pedals have a much smaller target price, so you've got to be very careful about unit material cost.
