Moderators: pompeiisneaks , Colossal
Gaz
Posts: 1146 Joined: Tue Aug 25, 2009 6:27 am
Post
by Gaz » Thu Jul 04, 2013 5:24 am
I like the early 70's Hiwatt EQ/pre a lot, and wanted to mate it with a Marshall output section and PPIMV to get some more crunch...
Success!... but it's super bright. One thing I'm trying to adjust is the amount of NFB. Looking at the Hiwatt, I see a 10K feedback resistor off the 16 Ohm tap, with a 2.2K shunt resistor setting the feedback ratio. Is that correct, or is there something I'm missing with the weird presence arrangement? If not, then that's a hell of a look of feedback, right? Like a crazy amount.
If anyone has any "bright" ideas to tame this preamp without killing the tone then I would appreciate it. Yes, I know a set of Fanes would help, but all I've got here are Celestions
Thanks!
[img
2550]
http://hiwatt.org/Schematics/DR_PreLinkedInput_v2.gif [/img]
eddie25
Posts: 260 Joined: Mon Dec 08, 2008 3:18 am
Post
by eddie25 » Thu Jul 04, 2013 3:13 pm
First thing I would consider is tinkering with a higher value for those 47n cathode bypass caps.
Posts: 15446 Joined: Wed Oct 17, 2007 1:01 am
Post
by Structo » Thu Jul 04, 2013 3:26 pm
I think the NFB is down there in the right hand corner.
It says the 10K is connected to the 16 ohm tap.
I would experiment with that value.
In my limited experience, the less feedback the more highs or gain will result.
On my Dumble I have a switch on the Presence pot, which kills the NFB.
The amp gets more gainy and brighter when off.
Structo on Fri Jul 05, 2013 7:11 pm, edited 1 time in total.
Gaz
Post
by Gaz » Thu Jul 04, 2013 6:00 pm
I should have already mentioned that I removed the 47n cathode caps, and it's still bright as hell.
I saw the 10K off the 16ohm tap, but am confused about the 470R/10n combo, is that sort of a fixed presence at really high frequecies?
chopstuck
Posts: 399 Joined: Fri Apr 25, 2008 5:09 pm
Post
by chopstuck » Thu Jul 04, 2013 8:40 pm
Structo, are you sure about that statement about highs, gain and feedback ?
My experience is the opposite.
Limited experience as well.
Marc
Heavens, an unused PI input !
Gaz
Post
by Gaz » Thu Jul 04, 2013 8:43 pm
I think someone said something backwards somewhere perhaps, but less feedback is more gain, highs, AND more bass.
bb5000
Posts: 41 Joined: Sat Nov 28, 2009 3:01 pm
Post
by bb5000 » Fri Jul 05, 2013 12:44 pm
I've built a DR201 and I have these values for the first stage :
Brilliant Channel: 1 uF cathode bypass cap, 10 nF coupling cap
Normal Channel: 25 uF cathode bypass cap, 22 nF coupling cap
I'm using it for bass and both channels sound good.
<b>LF Audioservice</b>
Built:
Weber AB200
Weber 6S100
Hiwatt DR201
Fender 6G3 Deluxe
Post
by Structo » Fri Jul 05, 2013 7:12 pm
chopstuck wrote: Structo, are you sure about that statement about highs, gain and feedback ?
Marc
Yes, I had a dyslexic moment there.
With less feedback the amp gets more wild!
