Options for subrack modules
LeftyStrat
Post by LeftyStrat »
I'm interested in some sort of submodule for rack mounting. There's the Paia FrakRak:
http://www.paia.com/proddetail.asp?prod=FR-7
I know there are some formats to accommodate Eurorack PCBs:
http://bigcitymusic.com/images/1000206_l.jpg
The problem with the Paia system is it is only front panel, and I'm worried about shielding between modules. Also the form factor is a bit small.
I'm interested in building a modular preamp system, somewhat inspired by the Egnator M4/ Randall RM4.
I seem to remember some format 'vero' something, that Craig Anderton mentioned in EPFM.
Anyone have any suggestions?
DonMoose
Re: Options for subrack modules
Post by DonMoose »
I always thought a server drive rack setup would be a good starting point - and a severely obsolete one based on SCSI would be pretty cheap.
Craigslist, Surplus stores or eBay, in that order.
Hope this helps!
LeftyStrat
DonMoose wrote:I always thought a server drive rack setup would be a good starting point - and a severely obsolete one based on SCSI would be pretty cheap.
Hope this helps!
Great idea, I hadn't thought of that. If I could find an older model with 5 1/4 drives it might give me enough panel space. That's another issue I'm running into is having enough panel space for say a Dumble preamp module.
DonMoose
Post by DonMoose »
You may have to go double-wide. Or stack a couple to get double-tall - remove one top and one bottom and strap together from the outside.
My current pipe-dream 'ToneLego' project is to be house in one of these that I sourced from some surplus stuff at work - a 13" tall bastard with a card cage and some other features.
Spendy, if you buy new.
LeftyStrat
I scored two of these from Goodwill for $4 a piece.
DonMoose
Post by DonMoose »
That sliding tray is pretty slick, and it looks like you could put your triodes upright on the inside, just under the vents. (surface/rail-mount relay-style sockets).
Aurora
Post by Aurora »
Schroff makes a large series of modular enclosures. Not sure who carries it in the US, though......
Farnell has them but frankly I don't know if it isa US company, or European???
LeftyStrat
Aurora wrote:Schroff makes a large series of modular enclosures. Not sure who carries it in the US, though......
Thanks. Looks like Newark in the US carries this line.
LeftyStrat
Vector Electronics was the other company I was trying to remember. I think their enclosures were mentioned by Craig Anderton in EPFM.
Aurora
Post by Aurora »
Come to think of it, Vero and Elma also used to have a lot of this stuff. I used Elma quite extensively - about 30 years ago :-)
Don't know if it still exists, and who might be US importers....
