Hi guys, i am going to be turning my princeton reverb test mule into a ods/reverb, probably using d'lite values, but without relays..
My question today is, i would like a tone stack without the extra switches, maybe just PAB, can you guys recommend values and what pots and such? or maybe just go with a fender type stack?
Or if anyone knows of a layout with a barbones stack in it?
Also going to try this with el84's to see how they sound:)
Barebones tone stack?
Hey man, you're leanin on my dream......
Re: Barebones tone stack?
Just remove the switches. If you're not using the HRM type ckt just go with values on the Hybrid.
ah k thanks bob:) i wasn't sure if removing the switches and caps and such that go with the switches if that would throw things off bad...
The only problem I've had with the elimination of switches has to do with the sound of the HRM OD. This sounds far better with the PAB on, so if you remove the PAB the HRM sounds pretty weak.Icetech wrote:ah k thanks bob:) i wasn't sure if removing the switches and caps and such that go with the switches if that would throw things off bad...
