Oscilloscopes for amp building...
				vibratoking
Re: Oscilloscopes for amp building...
I don't see the need for a 1x probe in a guitar amp, so 10x.  I would AC couple to look at power supply ripple.
Do you mean put a 0.1uF 600v cap in series with the probe to block the DC?vibratoking wrote:I would AC couple to look at power supply ripple.
				vibratoking
That is a safe way to do it.  The correct cap value will depend on the impedance of the circuit you are probing, the frequency you are looking at and the input impedance of your scope.  0.1uF should be fine for looking at power supply ripple with a 1Meg input.
Some scopes have a switchable AC coupling built into the front end.
I was gifted a Tek 466 which just needs some cleaning and bought a Hitachi V-212 for dirt cheap from a local surplus.
And, found a 10X CE probe for $3.00 at a thrift shop, brand new!
Coupled with another dirt cheap HP multi function generator I'm in business.
I was initially overwhelmed but with the help of the fine folks here and some YT vids it has been easy to learn.
Don't skip over the Jim Williams vids, he was a trip and a grand resource for learning.
https://www.youtube.com/watch?v=I6ODi7qSpYg
I'd appreciate links to videos you like!
This is just one of many, look at his other vids also:xtian wrote:I'd appreciate links to videos you like!
http://www.youtube.com/watch?v=OFGm-Pel4Hg
I tend to favor it because it's essentially the same as my Tek, but it applies to all standard analog scopes.
- JazzGuitarGimp
You've gotta watch this one up to about 5 minutes, when he says: "Alright, we poke around in inventory here for something around 15 microfarads..." I laughed so hard, I almost choked!Cygnus X1 wrote:I was gifted a Tek 466 which just needs some cleaning and bought a Hitachi V-212 for dirt cheap from a local surplus.
There are bunch of subtle jewels in that vid.JazzGuitarGimp wrote:You've gotta watch this one up to about 5 minutes, when he says: "Alright, we poke around in inventory here for something around 15 microfarads..." I laughed so hard, I almost choked!Cygnus X1 wrote:I was gifted a Tek 466 which just needs some cleaning and bought a Hitachi V-212 for dirt cheap from a local surplus.
I watch it about every 6 months!
It never occurred to me to check youtube to learn how to use a scope - duh, and thanks.
BTW you guys are bunch of dorksThere are bunch of subtle jewels in that vid.
- JazzGuitarGimp
Though I won't speak for the rest of the bunch, I can tell you I am GUILTY AS CHARGED!rp wrote:It never occurred to me to check youtube to learn how to use a scope - duh, and thanks.
You've gotta watch this one up to about 5 minutes, when he says: "Alright, we poke around in inventory here for something around 15 microfarads..." I laughed so hard, I almost choked!BTW you guys are bunch of dorksThere are bunch of subtle jewels in that vid.
