Does anyone has a schematic for a Blues Express?
Sven
						Trainwreck Blues Express
Re: Trainwreck Blues Express
See here:svenbode wrote:Does anyone has a schematic for a Blues Express?
Sven
https://tubeamparchive.com/files/wreckxpr.pdf
Scroll through the PDF till you see the A5h, A8a, A9h, and A9k designs. Also, see the design notes on the last page.
Re: Layout
Sven, I don't know of a layout for this specific amp but since it is a Trainwreck variant, you can easily start with the standardized Express preamp board and power supply board layouts, and convert the part values and/or add more turrets/eyelets as you need.svenbode wrote:Thanx, where do I get a layout?
That schematic and the parent document are quite old. There is some revision history on the last page of the PDF. I don't know anyone around here who has built the Blues variant. Most of us aren't really interested in variants of Ken's Trainwreck amps since the Express is a unique amp and behaves in a specific way (power amp distortion first, then PI, then preamp stages). Honestly, I wouldn't even call any of those amp designs Trainwrecks. They are not Trainwrecks, just variations on a theme.svenbode wrote:Who build one?
Hope that helps!
- statorvane
IIRC, the blues express was a series of mods to an Electar Tube 30 amplifier. I never saw a layout for one, I'm guessing because the mods were done on the Tube 30 PCB. There may be some gutshots on the web or at Blue Guitar.
Welcome, Sven.svenbode wrote:Does anyone has a schematic for a Blues Express?
Sven
Are you aware that you can access the real Express layout and schematic here?
The Blues Express was a best guess that was made before wizards at this site sorted it all out.
Be aware that the Express is a finicky beast to dial in. If you are just getting started yet still want some great tone, the Trainwreck Rocket is a much more friendly build.
G'luck.
+1000000 so much info on real Express's. Good luck with whatever amp you chose Sven, ChadZippy wrote:Welcome, Sven.svenbode wrote:Does anyone has a schematic for a Blues Express?
Sven
G'luck.
