Vintage MXR Micro Amp ATTACKED by Disintegrating Gray Foam!!
Toppscore
Post by Toppscore »
Hi. Any solutions to cleaning out this gray foam crud?
My two MXR Micro Amps are from approximately 1981.
Each Micro Amp has both the 9-Volt battery compartment
and the external side-port for an external power adapter
(one generation after the "battery-only" MXR Micro Amps).
Both Micro Amps work great! Just want to get rid
of the gray foam crud before anything happens.
What do you do?
***Heard this happens to all products with foam padding.
Fan of Fender Trainwreck Dumble
Bear
Re: Vintage MXR Micro Amp ATTACKED by Disintegrating Gray Foam!!
Post by Bear »
All I know is to yank the foam early and often. I've had some disintegrations in a rack compressor and an EV mic, too. The downside on the mic was needing to put a new sleeve in and wonder if I'll be any better off on that in 25 years.
Happy to hear any cleanup tips.
Baxtercat
Post by Baxtercat »
That stuff has turned to glue in several of my items...cassettes, speakers, etc.
Guitar Bob
TUBEDUDE
Post by TUBEDUDE »
I repaired two old Moog synths a few years ago. They were from the early seventies. I didn't make near enough on that job to clean up the mess that resulted. I still have some of it in my carpet. That foam turned into black glue with the slightest touch. That's why i refuse to work on keyboards anymore.
Toppscore
Post by Toppscore »
TUBEDUDE wrote:I repaired two old Moog synths a few years ago. They were from the early seventies. I didn't make near enough on that job to clean up the mess that resulted. I still have some of it in my carpet. That foam turned into black glue with the slightest touch. That's why i refuse to work on keyboards anymore.
Crap. I'm looking at a 1978 Roland 84-Keyboard
that I pulled out of storage since 1982.
Am praying it will play. Will let you know.
By the way. I cleaned out the two MXR Micro Amps
of the glue-like gray foam. I discovered EVERYONE
has the same issue. What a crappy mess that stuff is.
Have them both on EBay with plenty of before/after photos,
lots of pictures and lots of page views. Apparently my
1981 MXR Micro Amp is pretty rare? Who woulda thunk?
Sold my Boss DM-2 Analog Delay this morning for $415!!!
Toppscore :)
