Dr Z. Stang Ray build.... Video, pics and that crappy Hum
Firestorm
Re: Dr Z. Stang Ray build.... Video, pics and that crappy Hum
Post by Firestorm »
yalesmith wrote:Any ideas? This so frustrating!
Maybe update the pics so we know what we're dealing with.
Andy Le Blanc
Post by Andy Le Blanc »
sounds like 120, double check your grounds, whats the input jack?
It looks like a metal type grounding to the chassis...
If every thing looks correct and the buzz is still there, might try replacing the input with a plastic cliff jack with its own ground point.
could be layout, you got that PS filter cap right there by the input wire...
lazymaryamps
yalesmith
Post by yalesmith »
Here is one pic. As far as ground I have 3 ground points. The first is for all pre-amp ground, the second is for the power section and last is for the outlet.
