I was just adding in my 2 cents. you guys were doing fine.
And i agree, i'd just wasn't going to bring up anything about the copper cap, not touching that one with a ten foot pole...
As for what you are calling the bias resistor.. using a 150ohm for the pair.
And you have a 500ohm there now?.. the plate voltage will rise quite a bit.
The value of the cathode resistor will make the plate voltage change.
The plate voltage will be much higher using the 500ohm.
Using the 150ohm for the pair, the plate voltage will go lower as the tubes are running hotter,conducting more.
I know Phil S made a typo- meaning 6CA4.. not 6CA7. easy to type stuff thinking of other things.. Done it myself many times.
The 6CA4 is the rectifier tube used in the marshall 18 watters.
Or EZ81.
I know the weber layout /schem is a bit different. And different in values in parts of the amps power section compared to stock marshall 18 stuff.
So there may be some difference in the voltage between sections in the power supply stages.
I think most 18w that use a 1.5k resistor, see a difference of about 15 to 17 volts between the high B+ and the Screens.  Or plate and screens.
Cathode voltage can vary in the ballpark of around 10v. using aroung a 130ohm  cathode resistor. The tubes used or selected you may also see some slight differences in the voltage on the cathode. All tubes or pair will not be exact, but fairly close.
If you were to use a 125 ohm or 120 ohm cathode resistor,  the ballpark cathode voltage would drop some. If you went to a 180 ohm, then the cathode voltage would go up. Probably around 12 to 13v.
Just guessing here so don't take it as exact.. but will be close.
Hopefully this helps you see how these interact.
