Oh! And Houdini so maybe I can get out of having to do anything!
Merry Aftermath, St. Nick!
Mouser ordering pain in the rear
- Reeltarded
- LeftyStrat
Re: Mouser ordering pain in the rear
<full freaking rant mode>
I don't think any of the web vendors or schematic capture programs really come close to supporting the needs of the amp builder or effects builder.
Here's what we currently have:
- Insert symbol for input jack.
- Insert resistor symbol from a thousand choices for resistors.
- Insert triode symbol.
- Rotate the freaking resistor because it was inserted vertically.
- Connect input jack to resistor and resistor to triode.
Here's how it should work:
- Select from a choice of amps that are similar. Select output stages, phase inverter style, and number of preamp stages. Add or remove features such as Ampeg reverb, Fender reverb, etc.
- Oh wow, it calculated wattage for every resistor, based on projected current draw.
- Switch from a blackfaced Fender triode-tonestack-triode to a Bassman/Marshall/Vox tone stack.
- It has annotations from hundreds of builders about what sounds good.
- It builds a BOM suitable for Mouser, or others, with alternate suggestions for NOS parts.
- It shows tone stack curves.
</full freaking rant mode>
Someone, perhaps me, could write this. But I doubt you could get 1000 people to pay a $100 for it. Which is what it would at least cost to produce.
So you would have to give it away for free, and tack on a convenience cost. Most of us would save money on shipping if we could get everything from a single source. You'd have to get every vendor to drop ship and absorb the cost of shipping, and then tack on a charge to be profitable.
Probably won't happen, unless I score some peyote, buy an old airstream Bambi trailer, and take up residence in the deserts of California.
Just an idea.
Just an idea.
Someone beat you to it! I'm actually doing a demo for Fujitsu right now about this project: Easy DesignSim. It's for power supplies for LED lighting systems, and other simple circuits:
http://fujitsu.transim.com/login.aspx?lang=en-US
You start with a basic circuit, and you can modify any of the components, choose new components from lists provided by connected vendors (Mouser, DigiKey, etc) and when you're done, you get a BOM and even a direct link to the vendor's shopping cart.
We need a version for tube amp builders!
Couldn't find the complete BOM I thought I saw so I spent a few moments with a 2204 schematic and whipped up a resistor BOM using the old fashioned, non "Terminator" approach.
I scabbed in Mouser P/Ns which can be cut/pasted into their search bar to see technical details and to start a "project" there if desired.
Had visions of doing the whole kit-n-kabodle in one sitting but I think that was the sticky green bud speaking to me at the moment. Haven't seen any peyote since the late 70's so I had to leave it with just resistors for now.
Hope that it helps a little bit!
Dave O.
Dave O.
- Reeltarded
I was going to try it out but the second I saw mouser.com in my browser I started crying uncontrolably and then with the convultions like I had bad sushi two weeks ago.
My stomach hurts.
My stomach hurts.
