liverpool build
				mark enger
liverpool build
I cant open the file for the liverpool layout by ron worly all i have is a black and white copy and cant make out the values of the dropping resistors, and i cant realy see what going on with resistors r32 a and b looks like there tied together but im not sure   mark
						Re: liverpool build
Yes, R32a and b are tied together, in series.  Both 9k1, 2 watt.
R31 = 1k 25 watt
R33, R34 are 9k1, 2 watts.
Hope this helps.
Edit: Fixed typo on R31
													R31 = 1k 25 watt
Hope this helps.
				mark enger
Re: liverpool build
Yes that helps alot if someone could post the layout itself it would really help  mark
				rock_mumbles
Re: liverpool build
R31 is 1k - 25 watt
				Gibsonman63
Re: liverpool build
Layouts
https://tubeamparchive.com/viewtopic.php?t=5677
https://tubeamparchive.com/viewtopic.php?t=20
There is a 3D version on the second link that I found very helpful.
I will be well worth taking the time to move them to a thumb drive and getting them printed in color on 11 x 17. Get a couple of extra copies for troubleshooting.
				mark enger
Re: liverpool build
Thanks guys got it, now i can finsh up,  heres a pix I mounted a capcan in the chassis now to fit the rest of the electrolytics, i may just mount them in there sections on the board once again not enough pre build planning                                   mark
