SPLITMix4 to be use on a wet/dry setup?
- El Chiguete
Could a SPLITMix4 be use to independently split the signal to 4 efects and then mix it together?
						Re: SPLITMix4 to be use on a wet/dry setup?
I have never used the Splitmix4, but it looks like it is capable of doing the wet/dry/wet setup and do what you are looking for.
Still need the line level signal out of the amp, and a power amp/speakers for the wet side.
sean
sean
