Bought a 1954 variable power supply for breadboarding my amps. It slowly drops voltage over time. From 300 VDC to 280 v in 1hr. Other than tubes and electrolytic capacitors in general, any ideas on what part or block might cause this. Schem attached.
Thanks!
						50's HP 711A power supply problem
						Re: 50's HP 711A power supply problem
Interesting.
I'm not up on that circuit but I would think it had something to do with a R/C time constant that works inverted but I don't see any huge caps.
Must be the actual circuit that does it.
I would like to know as well.
I will work on it this weekend & let you know what I find-Structo wrote:Interesting.
Structo-Structo wrote:Interesting.
I changed all the tubes, electrolytics and selenium rectifiers & the thing still drops voltage slowly. There are only 3 caps left in the amp (600v bumblebees) so I will change those out then quit. I'll let you know if that solves the problem.
				Cliff Schecht
Sounds like a drifting resistor to me..
									Cliff Schecht - Circuit P.I.
