Acoustic Bolt on Neck
Any reason an acoustic body wouldn't work if it was built to accept a bolt on Strat neck?
Re: Acoustic Bolt on Neck
Fender did this on their acoustics in the '60s, so yes, it will work. How well is open to debate.
I used a neck from a donor Fender 12-string acoustic to make a 12-string Telecaster. The body had begun to delaminate and the bracing was bizarre. I bought it as scrap at Elderly Instruments' garage sale about 20 years ago for $30 IIRC.
It'll work.  The better question is, how well?  Unlike an electric, which will forgive a multitude of sins as a consequence of amplification, an acoustic is not at all forgiving.  Everything in the vibration path contributes to tone.  A bolt on does not make contact they way a fitted and glued neck does.  The  transmission capacity is likely reduced and some harmonic content is probably lost.  It could be OK, but I don't think it will ever be great.
				Randy Magee
Aren't all the current Taylor guitars bolt on necks?  I can't say that I've heard many of them that didn't sound pretty darn good...
									Randy Magee
Many acoustics have bolt on necks nowadays but they are still in a V slot so there is a lot of contact between neck and body.
My Tacoma has a bolt.
The old Stratacoustics and Telecoustics were pretty cool little guitars.
I played with a touring pro once that had a Telecoustic that was tricked out with an extra pickup and controls and man that thing sounded great.
[img 402]http://media.fmicdirect.com/fender/imag ... lg_001.jpg[/img]
I see Fender is going to reissue these, different pickup and controls now.
Here is a refirb for $178
http://www.newsongmusicsupply.com/fende ... re=newsong
[img
- Reeltarded
It's been done since the modern acoustic guitar made it's debut in the early part of the last century, and I have seen even a 180 year old instrument with a spiked neck set that I couldn't replicate or explain if I tried really hard.
It works.
It's not as simple a thing to say that it won't sound as good. No comparison.
						It works.
Not like Fender, but Taylor necks are bolted on. http://www.frets.com/FretsPages/Luthier ... joint.html
				oldhousescott
Certain Epiphone acoustics from the '70s had bolt-on necks similar to an electric bolt-on.
									"We put a little quality in everything we build..."
Some EKO acoustics have bolt on necks. I used to own a Ranger 6 string, sounded alright. Wasn't very loud tho.
				Cliff Schecht
My Simon and Patrick D-28 style acoustic sure does sound and play great for a bolt on guitar. Thing is it's not a low dollar guitar either, my dad said he paid like $1200 for it in the early 90's, and it sits well next to any Martin I've put it up against. Bolt-on necks are not a bad thing at all if done right..
									Cliff Schecht - Circuit P.I.
Oh and I do own a baby Taylor with a bolt on neck. I love the sound, its an awesome little guitar.
My brother has a Yamaki from the 70's.   It's got a bolt on neck.  Decent for a cheap guitar, though the original bridge was in the wrong place.   I think the scale might be 25", so you'd have to get a conversion neck.
Good point! Yes, I think that's right, and they use CNC technology that probably produces a micro fit. And yes, they are great guitars.Randy Magee wrote:Aren't all the current Taylor guitars bolt on necks? I can't say that I've heard many of them that didn't sound pretty darn good...
I don't think the OP imagined that sort of fitting technique.
- Reeltarded
A Fender style maple neck will sound much different from a mahogany neck. Those Malibu and similar Fenders have a very weak projection compared to modern Taylors or most anything else mentioned here except the Danny Ferrington designed Kramers which don't project anything in particular.
				Cliff Schecht
That's debatable. I've always found Taylors to play like the el-cheapo Ibanez's that are typically accompanying them in the same room. I've played $4k+ Taylors that weren't worth a fraction of the cost in terms of sound quality and playability (although a setup can usually fix the latter). I think where Taylors do shine (and IMO what they were made for) is playing acoustic-electrically onstage.Phil_S wrote:And yes, they are great guitars.Randy Magee wrote:Aren't all the current Taylor guitars bolt on necks? I can't say that I've heard many of them that didn't sound pretty darn good...
