grounding unused 1/2 of 12ax7
do you just leave the 3 pins there or do you ground the. i've seen it done both ways.
Re: grounding unused 1/2 of 12ax7
I say leave them non-grounded.
I only grounded the pins on my Zwreck build because Dr Z did otherwise I only do that on some octal pre-amp tube builds that have deflector plates, etc.
