skyboltone wrote:I've often wondered about the wisdom of two test points for fixed bias in a push pull amp. Even with the best of "matched" tubes there is always a few ma difference. So you set it so one's a little hot and the others a little cool compared to your goal. What's the point of that? After all is said and done (redplateing aside) don't we just set bias so it "sounds right"?
Why not put a single one ohm resistor between a common tie point for both cathodes and ground, then measure the combined current as a starting point; then set it where you like it without having the pair over limits?
Comments appreciated
Dan
Digging up an old thread here....
I'm building a 6G6B Bassman(actaully 2) and I would like to keep it externally as stock looking as possible and any additional holes to a very miminum. Since there isn't a ton of real estate I have been debating for the last few days on the location for the bias test points.
Earlier to today I was thinking the exact same thing that Dan mentioned above.
Here's what I think I'm going to do, mount the 1 ohm resistor on each power tube, but only install one red test point in the chassis. This still would provide full functionally for resistor biasing from the inside of the chassis, but obviously you can't measure both tubes at the same time externally. However, you could move the the non TP tube to the TP socket and check it there.
Since this is my personal build I don't really mind this scheme, but I wouldn't sell an amp this way. The another build for a client will have the 2 tests points(wherever he chooses) and a tube rectifier option.
TM
