I've almost finished a d'lite down under (Australia
Moss kindly suggested taping bias supply from the HW using the diagram attached as a guide.
It was mentioned to re-configure or make a new rectifier board, you will need the 2-3w 220K dropping resistor (in place of the 470R)
following the schematic would dictate that you change the 100uf cap to a pair of paralell connected 47uF/100v balanced with a 15K 2-3w resistor.
What are your guys thoughts on values to get -50v??
Once i get over this hurdle I should be able to get the amp up and running.
I'm not so familar with this stuff. thanks in advance.
