Software for Layouts and schematics
plook
Post by plook »
Can anyone point me towards Mac software for doing layout and schematics.
MCK
Re: Software for Layouts and schematics
Post by MCK »
I used JSchem just recently. Not perfect but for a free app it does the job. Comes with some existing library elements which you can use in your schematics etc.
10thTx
Post by 10thTx »
http://dhost.info/jschem/
I think it will open ExpressSCH files also. In which case, there are hundreds of editable schematics here:
http://www.el34world.com/Forum/index.php?board=12.0
With respect, Tubenit
plook
Post by plook »
That's brilliant for the schematics. Anything out there for layouts? ConceptDraw told me they will incorporate it into future releases and send me a Beta copy for testing, but that could be a long way off.
10thTx
Post by 10thTx »
Sure, there are plenty of editable layouts using the same program in the EL34 World link that I posted.
With respect, 10thtx
Visio makes the prettiest layouts. :D
plook
Post by plook »
I'll have a closer look for those layouts on that link.
Visio is great, but not available for Mac as far as i know and ConceptDraw is the closest second best.
Gaz
Post by Gaz »
plook
Post by plook »
I can't seem to get it to work on a mac, though it says it's multi-platform
MCK
Post by MCK »
Just tried it on my Mac. It runs. You need to double-cilck the diylc.jar file. You need Java support installed on your Mac.
plook
Post by plook »
Thanks, it works perfectly.
MCK
Post by MCK »
plook wrote:Thanks, it works perfectly.
Most welcome. Look forward to seeing your creations
Milkmansound
Post by Milkmansound »
I use autocad for everything
not an inexpensive option, but highly recommended.
Also, I know another amp builder who does everything in Adobe Illustrator
plook
Post by plook »
Milkmansound wrote:I use autocad for everything
Do you and your friend have to create a library of components though?
Milkmansound
yeah, I made blocks for tubes resistors capacitors and diodes - didn't take very long.
the real win with autocad is the turret board layout - I measured and drew each component and placed turrets around them. The result is beautiful - especially for the big Sprague caps.
I also map out every screw hole and use the same template that I have for turrets as a drill template to mount the board to the chassis - perfection every time. Autocad is great for that kind of thing.
